De Dietrich DTI1049X1 Tripping RCD
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries De Dietrich DTI1049X1 Tripping RCD
  • #83003
    Taff
    This induction hob trips the RCD when using the centre hot plate. The plate works but trips the RCD when it reaches temperature. Both plate and power module pass the insulation test. Does anybody have information or experience of these hobs on which component would be faulty, plate or power module?
    Regards
    Taff
    #421407
    Allsorts
    Re: De Dietrich DTI1049X1 Tripping RCD
    How are you testing the plate insulation?
    The breakdown could be cumulative when hot
    #421408
    Taff
    The power card was causing the failure
