De Dietrich DTI304B Induction Hob
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries De Dietrich DTI304B Induction Hob
  • #22210
    cookerfit
    LHS rings on this unit completely dead as are controls on LHS. RHS operates OK. Visually can see or smell no burn outs. Power arriving at LHS power board OK.
    Does anyone know if there are any one shot TOC’s on the board or anything I’m missing before ordering 200 quids worth of PCB’s.
    Cookerfit
    #194063
    bzz67
    Re: De Dietrich DTI304B Induction Hob
    going a atag induction hob tomorrow with the same fault.never had to look at one of these before,i will let you know what i find.
    #194064
    Whatever happened to the days when De Dietrich (in Basingstoke) used to have all the tech info available for their agents eh? :rolls:
    And you could get bits out of their stores and try them out to see if that cured it? We even robbed parts from their demonstration kitchen induction hob and ovens when things got desperate…. :rotfl:
    Oh those were the days………. :stir:
    P.S ….But what a coincidence this is?……
    http://www.ukwhitegoods.co.uk/modules.p … 593#106593
    #194065
    cookerfit
    Thanks Martin but have verified live & neutral to each of the powerboards (info from link).
    Re the ATAG, if its valid, there seems to be some common part numbers between FAGOR and De Dietrich induction hobs – at least on Connect!!
    Regards
    Cookerfit
    #194066
    cab
    is this new or old, if new there are jumpers on certain models that must be put into the terminal block, if it is old it will be the power board, both sides are independant, you can swop the boards to confirm faults.
    cab
    #194067
    bzz67
    just come back from the atag job.it was simple,as one of the neutrals in the 5 core flex was badly fitted into the mains isolation switch.
