Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › De Dietrich Freezer cooling problem
- This topic has 6 replies, 2 voices, and was last updated 12 years, 7 months ago by
Hyde.
August 16, 2013 at 9:15 am #76703
Hyde
ParticipantHi
Had the above freezer for around 5 or 6 years now and yesterday it started bleeping with a temp reading of -11 when normally it reads -18.
Model is DFS620JE
Type is B227446
Prod No is 922 744 715
Ser No is 080500110I think I can hear the compressor kick in from having switched it off but it’s very quiet.
Overnight it’s maintained the -11 but I simply can’t get it to go back to -18.
Any thoughts please?
TIA
August 16, 2013 at 5:14 pm #399481maltheviking
ParticipantRe: De Dietrich Freezer cooling problem
The compressor will be very hot to touch if it is running.If it is hot and the freezer is not getting cold enough then you may have a system problem (faulty compressor or refrigerant leak)generally not economical to repair. If the compressor is cold then you may be able to have the unit repaired but I would suggest you leave that to an engineer
August 16, 2013 at 6:54 pm #399482Hyde
Cheers. It’s a built-in jobbie so can’t access the compressor without unscrewing the unit from the cabinet surround 🙁
August 16, 2013 at 7:32 pm #399483Hyde
Have found that their service dept is based where I live in Basingstoke via this website, so I’ve completed their contact form for service and repairs. I’ll see what happens next 😮
August 16, 2013 at 7:34 pm #399484maltheviking
Hyde wrote:Cheers. It’s a built-in jobbie so can’t access the compressor without unscrewing the unit from the cabinet surround 🙁
Welcome to our world good luck, good idea to switch off the electricity before you move it
September 4, 2013 at 9:32 am #399485Hyde
De Dietrich have sent Service87 agent round. Apparently the fan is frozen solid in it’s hood at the top of the freezer. Part needs to be ordered and fitted. Another wait 🙁
September 15, 2013 at 4:19 pm #399486Hyde
All fixed 🙂
Fan is a bu99er to replace. Took the engineer and me to hold the casing up whilst he backed himself into the freezer to work on the back of the chiller. Very difficult holding the casing up without stressing the copper refrigerant pipe.
Not the best design I’ve seen 😉
