We have a DTI749X Continuum induction cooktop by De Dietrich and we now get the error code F0 on the two right hand zones, which means CTN electro temperature. We are not quite sure what CTN electro temperature means and would like some advice on what it is, what could cause it and what we have to do or what parts we have to buy to fix it.
Thanks in advance
sorry for late reply just seen post
fo is showing abnormal temp on ntc poss cooling fan blocked or not running if fo showing on both elements poss pcb if only flashing on one change ntc
i was just wondering if it was your pcb ,and if it was did you get a replacement from dedietrich, as i have the same model and have been waiting since mid november for them to supply one. they are a waste of fresh air
