De Dietrich Induction Hob
  • #55173
    blokes
    Hi all, Ive been to a De Dietrich Induction Hob DTI309 today. Never worked on one before.
    If you place a kettle on one of the rings and press the boost button, all I get is bo flashing on the display.
    Anyone got any experience on these beasts !!!
    #322166
    timdowning
    Re: De Dietrich Induction Hob
    Now I know absolutely zilch about cookers & hobs, but don’t you need a certain type of base on the kettle, saucepan etc to get the hob to work?
    Does it work with saucepans?
    Tell me to get my coat if you want!
    #322167
    blokes
    Well I assume they have the right sort of kettle, as it works on the other four rings of the hob!!!!!!!!!!!
    #322168
    Jazzmeister
    You more than likely have a problem with the pan sensor or main board then!
    Jazz
    #322169
    funkyboogy
    if you get a flashing display you have more than lightly used a wrong pan.. pans need to be non ferrious
    something to do with induction/emf fields .. pan completes the field ..
    but if pan doesnt have good magnetic properties it wont return/complete field..
    best way to check is stick a magnet to pan ..
    wow i fell like steven hawkins now .. quite a complex issue ..
    not used to replying to complex problems .. hope it makes sense ..
    and there is a possibility pan sensor faulty..
    ally
