Re: De- Dietrich, Induction Hob. DTI704V
In order to determine if it is the power card or keyboard card, you will need to swap over the left and right power cards to see if the fault transfers to the other side of the hob. you do not need to remove the coils from the power cards to do this only the mains connection the bus wire connection for the keyboard card and the earth screw. The code is a config code that is factory set and is not a fault code this clears after 30 seconds or so, or if the controls are used.
Hope this helps
