Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › De Dietrich Induction Hob Fault
- This topic has 5 replies, 2 voices, and was last updated 2 years, 5 months ago by
steverob1066.
October 31, 2023 at 1:31 pm #102345
steverob1066
ParticipantI have a feeling I know the answer to this but…
The left hand elements on my De Dietrich induction hob suddenly turn off while cooking, the display goes blank and then nothing I can do restarts them, except waiting after switching off at the mains. The right hand hobs are fine. This hob has worked faithfully over many years and I shall be sad to see it go if it is truly kaput. But does someone know better? Can it be rescued?
If not, any recommendations for a slot in replacement at 77cm x 51 cm?
October 31, 2023 at 7:01 pm #488427electrofix
Moderatoreach board has a cooling fan and it may have failed
October 31, 2023 at 9:45 pm #488428steverob1066
Participantelectrofix wrote: each board has a cooling fan and it may have failed
Thanks Dave – is it feasible to repair? I had a quick look at the various spares companies and none of them stocked De Dietrich fans for induction hobs.
Also – if, as seems likely, I’m going to have to buy another hob (if I can find one with an identical cutout), I see many of them need heatshields underneath the hob (if the hob is above a drawer, as in our case). My old hob didn’t have one, so this is turning into the old woman who swallowed a fly. Are heatshields a safety issue, or just a nice-to-have?
November 1, 2023 at 9:29 am #488429electrofix
Moderatornever come across heat shield but there is less need on an induction hob as there is less heat transmitted downwards
as for the fan have you got a model no ?
November 1, 2023 at 1:02 pm #488430steverob1066
Participantelectrofix wrote: never come across heat shield but there is less need on an induction hob as there is less heat transmitted downwards
Thanks – it’s a De Dietrich DTI318
And this is what happens:
- The left hand side hobs start as expected when the unit is switched on.
- The left hand side fan runs as expected.
- After 5-10 minutes of running one of the hobs at 11, the left hand side fails. Just as it does so, there’s a clicking sound of an inside relay, maybe a double click, the fan switches off, the display flashes the heat setting once, then goes off. No amount of fiddling around with the buttons can restart it.
- Rebooting the unit after 5 minutes, the left hand side works again – until the next time…
November 2, 2023 at 9:55 am #488431electrofix
Moderatordoes sound like something is getting hot and failing
you do seem to be able to get a fan but no stock where i looked
its worth checking that the fan seems free to turn. and the correct one is turning as there is more than one fan in the unit
I assume if you operate the left side on lower powers it either takes longer to cut out or doesntalso as a long shot check all screws in the terminal block and make sure they are tight
