De Dietrich Induction Hob Problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum De Dietrich Induction Hob Problem
  • #22220
    boycie99
    I hope someone can help me here and the problem I have is a caoomon problem and easy to resolve.
    Having moved house I have inherited a De Dietrich induction hob.
    Type No: WE5859E11
    Ref No: L522EDY21
    Series No: 99/08/99302
    We have had some new worktops fitted and so have had to move the hob while the work was done… when we reconnected the Hob only the right hand side of the hob worked. There was no power at all to the 2 left hand side heaters.
    Any help would me much appeciated
    Steve
    #194090
    Re: De Dietrich Induction Hob Problem
    Hi Steve
    This would normally be a installation wiring fault,if the hob isnt wired correctly then only either 1 or 3 will work.
    Bryan
    #194091
    boycie99
    Thanks Brian,
    The hob had been working properly prior to being moved around… I have checked the wiring and made sure the 2 live wires are connected together and the 2 neutral are connected together but the problems still exists… I am guessing there is a problem inside the hob that will need to be looked at
    Steve
    #194092
    bobthefireman
    Hi there. I have exactly the same problem with my De Dietrich Induction Hob. i was wondering how you resolved the problem 🙂
