Anyone know how to bypass the Pyrolock on this oven?
Customer put it on pyroclean and realised there was food in it so they turned it off and pressed every button to try and open it.
Eventually the had to switch it off at the wall to opget it open but now nothing will turn on.
The clock works and you can set it etc. but no grill or oven will work.
i’ve ordered a Pyrolock but its not going to be in for ten days so I’d like to bypass it in the meantime to get them going.
Anyone got a manual please or know how to bypass it.
I’m bumping this as i’ve the same problem again, with the same people!!!
They switched it off at the wall not knowing it was on pyroclean and now nothing but the light works.
The last time i waited for a new lock but i’m hearing a bit about PCB’s blowing on these and dont want to be stuck with a lock if its not the only fault.
