Home › Forums › Public Support Forums › Spare Parts Help › De Dietrich oven element
- This topic has 8 replies, 2 voices, and was last updated 15 years, 7 months ago by
yoghurt.
August 26, 2010 at 3:56 pm #56816
yoghurt
ParticipantHello
I have a De Dietrich oven
Type FM4445E299
No.99-48-04266
P.MAX 2.9
Constructeur 419I have emailed spares to find availability/price for a new element as the cooker is now very slow to warm up (30 min to get to 180 degrees).
I did get it replaced a few years ago (and had a hard job finding the part) by an oven repair man.
My question is – is replacing the element relatively straightforward (I am not trained but like tinkering with electrics and would ensure the oven is turned off at the mains and fuse box) or is it a big no no and should only be attempted by a qualified/trained person?
Many thanks
Yoghurt
August 26, 2010 at 3:58 pm #328942kwatt
KeymasterRe: De Dietrich oven element
Hi Yogurt,
It is this fan element and it’s pretty easy to change without removing the oven.
HTH
August 26, 2010 at 5:02 pm #328943yoghurt
ParticipantRe: De Dietrich oven element
Many thanks K
I had a fast response from the spares section too
Cheers
August 27, 2010 at 10:46 am #328944yoghurt
Doing a bit more reading on this forum and it has occurred to me it might not be the element but the fan.
As well as the cooker being slow to warm up the fan makes a resonating noise for about 5 minutes when it is first turned on.
Could it be the fan needs replacing and in turn this has affected the performance of the element? If so is the fan also straightforward to replace?
Many thanks
Yoghurt
August 27, 2010 at 9:32 pm #328945kwatt
Hi Yoghurt,
Yep, could be a fan motor fault and that could have led to element failure.
The fan motor, not so easy to replace yourself I’m afraid, it’s an oven out and strip off the back job.
HTH
August 31, 2010 at 11:09 am #328946yoghurt
Thanks kwatt
September 5, 2010 at 6:56 pm #328947yoghurt
So I spent Sunday morning learning whats inside my oven!
I was very cautious and tuned off the oven main switch at the wall, the circuit for the oven AND the main power switch for the whole house.
I managed to get the fan cover off to reveal the element and got the back of the oven off to gain access to the element screws-however I just could not get the retaining nuts off!! The nut was on each of the threads and because the threads were quite long I could not use my long nose pliers or socket set to get to it. Is there a special tool I need? It did occur to me I was trying to unscrew in the wrong direction (tried anti clockwise)
2nd problem was the fan I purchased was one of 2 possibilities and guess what-I think I chose the other one that did not fit! We purchased the oven around June 2000 so chose 76X3718 however it did not appear to be the correct one as I had to remove the 3 ‘spacers’ from the oven for the 3 legs of the motor to go through (which was fine and aligned no problem) but the screws from the spacers did not fit and the motor did not come with any. Apart from that it looked like the right one so should I have just got some different screws? The alternative motor is ref 77X3597 for ovens made after 27/6/2000 but this does not look right.
Must say I felt a bit like a gynaecologist trying to access parts of the oven!
The element did look pretty mucky. Our current motor makes a reverbating noise for a while when first turned on (although nothing obvious blocking it)-I guess a new motor would help with this
Any advice appreciated!
Cheers
Yoghurt
September 12, 2010 at 7:54 pm #328948yoghurt
ok 2nd Sunday and fan installed and working as well as new door seal
All I need now is to get the nuts off the long thread on the element
Having trouble finding the appropriate tool-some sort of socket set which is long and hollow? Or is it a special tool?
Any advice much appreciated
Cheers
Yoghurt
September 12, 2010 at 8:03 pm #328949kwatt
KeymasterIIRC they are TORX bits.
