Customer says that after heating for a while on fan thw whole cooker cuts out. Thye digital clock timer is very dim and you can hardly see to set the time.
Is it likely to be clock timer or there are 2 tocs fitted outside on top of oven.
Any help please.
Mike
could be one of the limiters. One is for the cooling fan and one the overheat. I cannot tell from the exploded view which is which, will need to check the values. part number 92X6023 for the front one and 75X1509 for the rear might also be the cooling fan. the display sounds unrelated but part number 78X2289
