de dietrich oven won’t unlock!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum de dietrich oven won’t unlock!
  • #4962
    I ran the pyrolytic cleaning function on my De Dietrich oven this morning, and it still won’t unlock 10 hours later. Help please!
    #106661
    bonzaco
    Re: de dietrich oven won’t unlock!
    Hi – could you confirm how long you have had this appliance, and its model number. With De-detrich the fault is usually associated with a model number or frame assy. Cheers – Bonz
    #106662
    Sadly the model number is on a rating plate inside the door on the leading edge of most from memory.
    There is a lock in most that slides across the top edge of the door, if you can get to it push the catch to the right as you look at it (from memory I could be wrong) and that should release the door.
    It should have released after that length of time so my guess is it’s a failure in the lock. Total pain as the screws that hold the appliance in are behind the bit you have to open.
