I could do with some advice.
I want to replace the ignition switch on my AL60GA (precursor to the AL60GAC) but wonder:
A: I am legally allowed to do this, not being a registered/qualified gas engineer?
B: How the devil do you get the old one out?
any repair on gas appliances should be carried out by qualified engineers. If you try it yourself and you cause a gas leak it could be a big problem. A gas safe engineer will check the whole installation for leaks after the job has been done
Thanks Dave, I’ll take your advice. I suspect the ignition switch had been super-glued then attached by a gorilla in a bad mood. I’ll call in the experts: someone with a big wrench or a hammer! Cheers, Bill
