Dead oven
  • #77195
    yorkie86
    Not having much luck with ovens at the moment, ahem.
    I have a new world 444447228
    http://www.appliancesdirect.co.uk/p/444 … ric-cooker
    It’s slightly over a year old, not been used much, had the hob on OK last week, this week tried it, nothing comes on at all.
    Doesn’t have a timer as far as I know, tried the fuse, not that. Because it’s quite new it wouldn’t have an internal fuse would it?
    Is there anything else obvious I could check before I call a man in? 🙂
    #401346
    Re: Dead oven
    You said in your microwave thread that you didn’t have a conventional oven, now it appears you do. You say the hob on it doesn’t work so do I take it that the oven and grill doesn’t work also? If the answer is yes, have you checked the wall switch as well as the fuse box?
    #401347
    yorkie86
    Re: Dead oven
    Don’t have a WORKING conventional oven, amounts to the same thing – I am ovenless.
    When you say have I checked the wall switch do you mean have I checked it’s on (yes it is) or do you mean have I checked the wiring inside switch (no). Like I said it was working the other week so it’d be surprising if it was that? I’ve checked the wiring connecting the oven, that seems OK.
    Cheers.
    #401348
    Re: Dead oven
    yorkie86 wrote:Like I said it was working the other week so it’d be surprising if it was that?
    I wouldn’t. 😉
