Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Debor Glue
- This topic has 13 replies, 11 voices, and was last updated 16 years, 6 months ago by
Phidom.
September 23, 2009 at 6:15 pm #48815
ParticipantI’ve never really used this before as I’ve used silicone but it seems to be favoured by several people on here so I got a tube. The tube is printed in the foreign so how long should I leave joints to dry before leak testing?
September 23, 2009 at 6:31 pm #297812chezza
ParticipantRe: Debor Glue
Blimey,is Debor still available ? I remember 30 odd years ago when I started work and the reps from wash vac, maddocks etc used to call and there would always be an order placed for tubes !
Memories of standing on tubes which then split on carpet tiles :rolls: …
and a very vivid memory of a very hairy dog running down a customers garden with a tube stuck to its muzzle , and by the time it was caught, there was half a forest stuck to its head, along with the still stuck tube completely matted up amongst its fur !
And as for the smell that used to linger in the tiny honda acty van….i was permanently floating !!
Happy days lol ( sorry, not sure of the answer to your question , but the standard advice used to be to advise long enough for you to be out of the area before attempting use 😆 )September 23, 2009 at 7:09 pm #297813deltra
i allways say leave 24hrs 8) (plenty of time to get away 😈 )
September 23, 2009 at 8:34 pm #297814Cras
used debor for years got me out of many a tight spot i normally apply a covering to both surfaces leave for 10 mins before putting together ,i have to agree though you leave it in your tool box at your peril 😆 Chezza the honda acty was a fantastic little van my dad had one in the eighties for his refrigeration business 1 wheel drive 500cc and a top speed of 85 😉 well i was only 18 😆
September 23, 2009 at 11:15 pm #297815leavemetogetonwithit
There’s no need to wait with debor. The solvent is so volatile it will form a skin in seconds. By the time you’ve got the plug in and the water turned back on it’ll be water tight.
Ah…. that’s if you’ve used it to seal a hose connection which would probably have been OK without it anyway.
If OTOH you’re using it to repair a rusted drum, then you’d better leave it for a week, and then be ready for a call back. It ain’t meant for repairing holes in drums. Nor for repairing rotted hoses. I’ve seen the disasters that result from such attempted repairs.
I used debor for the last twenty years but recently switched to silicone for most purposes thinking it less likely to injure my health.
Mike.September 24, 2009 at 4:08 am #297816chezza
Cras wrote: Chezza the honda acty was a fantastic little van my dad had one in the eighties for his refrigeration business 1 wheel drive 500cc and a top speed of 85 😉 well i was only 18 😆
If I remember correctly, I originally had a 375cc single stroke with the engine accesible through a plate in the floor of the rear, before I was upgraded to the luxurious 500cc version ( I am sure Mark will remember 😆 )
September 24, 2009 at 6:29 am #297817neilsukwg
Glue Finger
The habit of spending hours casually picking remenants of Debor from one’s fingers is a well known side effect, and one that gives one the appearence of a nervous schoolchild awaiting 6 lashes outside the headmasters office.And Debor stuck on the work trousers and/or jacket giving the appearence of someone who has just crawled out of a skip!
Good stuff though to get you out of a sticky situation.. 😆
September 24, 2009 at 6:59 am #297818eastlmark
ModeratorRe: Debor Glue
In my experience, all of it ends up on your hands and the joint you have just applied it to is completely clean of the stuff. Not used it for years. The quality deteriorated a few years back as it started to come out of the tube in an oily mess as if it has seperated in the tube. Not missed!
Had a tube fall across the live terminals of a mains filter once…..the scene of a mini napalm attack in the customers kitchen will never be forgoten.September 24, 2009 at 8:36 am #297819A1engineer
ive got a huge dollop of debour in the back pouch of my toolbox, that in itself is a lasting reminder never to leave in toobox again….
i still use it for sealing t/stat gaskets and for the drain hose of servis door seals other than that not much call for it.
ps it doesnt seal a cracked tub 😳
September 24, 2009 at 5:08 pm #297820Phidom
Ah I had wondered if it would stick to plastic tubs better than silicone. I tend to weld small holes with the soldering gun but sometimes you still get a minute seepage if the weld is a bit porous. Did one on a welded tub machine a few weeks ago. I put a thick layer of silicone over quite a big area surrounding the weld but I had wondered if Debor would have stuck better.
September 24, 2009 at 6:41 pm #297821deltra
that plastic putty from masterpart is great for repairs to holes in plastic tubs.
September 24, 2009 at 9:47 pm #297822philfish
Very old but milliput does the trick sets like rock!!! will fill small cracks and holes sets under water etc. You can even tap and screw it. 😆
phil
September 25, 2009 at 4:22 pm #297823maltheviking
leavemetogetonwithit wrote: I used debor for the last twenty years but recently switched to silicone for most purposes thinking it less likely to injure my health.
Mike.Then you should stop sniffing it mate :rotl:
September 27, 2009 at 6:11 pm #297824iadom
maltheviking wrote: Then you sould stop sniffing it mate :rotl:
Many years ago when working for Hotpoint we used to get a Debor type adhesive supplied in large tins. The only way to get it out was by dipping a screwdriver or your finger in it. 😥
On one occasion whilst my van was off the road I had to borrow another van from an engineer who was on holiday.
After driving for about 20 minutes or so I began to feel a bit light headed and dizzy.
Opened the back doors to find his tin had tipped over and was oozing out all over the place. 😯
I find Debor seals rubber hoses and grommets to metal better than silicone.
