I managed to get myself talked into looking at the this steam oven that blows the trip after a couple of minutes and have found that it has been leaking from around the heater mounting. Can anyone advise on the part numbers + supplier for the Heater plus the thermostat mounted underneath. also the casting that is inside the oven above the heater is corroded and will also need replacement & poss seal
Colin
