DeDietrich CX4844 Oven/Programmer Fault
Home Forums Public Support Forums Spare Parts Help DeDietrich CX4844 Oven/Programmer Fault
  • #57381
    adwsys
    Hi All,
    I have a 8 year old DeDietrich CX4844 Range Cooker on which the large (left hand) oven & grill have stopped working. I’ve had a look at all the connections & the spaghetti mess of wiring inside the cooker & AFAICT there are no loose or broken connections. The small (right hand) oven & grill are working normally which leads me to believe that this might be a programmer problem. I’ve had a look on the Internet for a replacement programmer & the only place I can find them is on the PartMaster web sites, but they’re priced at an unbelievable £520. So my questions are:
    1. Am I on the right track with my diagnosis of the fault?
    2. If it is the programmer, is there anywhere I can get one for less than the price of a new cooker?
    TIA,
    Andrew
    #330976
    funkyboogy
    Re: DeDietrich CX4844 Oven/Programmer Fault
    if you take the back of and round about the centre area job below hob there is a toc , if this fails your right oven/clock wont work ..
    check this 1st , clock is a lot cheaper than you have been quoted
    ally
    remember power offffff
