Hi This is the 1st one of these I’ve been to can anyone give me some tech info on it,The fault on the display says water tank fault but this has been replaced anyone have any ideas ?
thanks mark 🙂
Water system error is normally a leak from one of the boiler hoses this leaks into the base and is picked up by a sensor. Look beneath the heater and you will see signs if a leak.
