Trying to find data regarding how this function operates. i.e its modus operandi.
Does anyone have any info regarding the sensor that fits into the air conveyor and whether this is a “usual suspect”, also where the catalytic converter fits into the equation
Oven works fine in every other mode and cooling fan has no problems.
Re: DeDietrich DMP501E1.1 Trips TCO on PYRO Function
hi not very good with model no`s etc, but have had loads of single pyro ovens that the toc trips because they are not installed correctly. If they dont follow the install instructions incorrect airflow can cause the toc to trip only on pyro.
