Dedietrich DOD448XG1 low temperature
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Dedietrich DOD448XG1 low temperature
  • #86812
    slyp98
    hi all , this one only heats to 80 degrees its set on maximum temp. i cant see a thermostat any info appreciated
    #433089
    slyp98
    Re: Dedietrich DOD448XG1 low temperature
    Bump
    Sent from my HTC One mini 2 using Tapatalk
    #433090
    slyp98
    anyone ?
    #433091
    blackandwhites
    looked at the parts info and it has a temperature probe instead of a thermostat.Part number is BNT74X4563.
    #433092
    slyp98
    cheers blackandwhites do you think this would cause the above fault , i dont want to find out it needs a new pcb instead, are there any values for the resistance of the probe
    #433093
    blackandwhites
    Sorry don’t know the values of resistance for the temperature probe.It is most likely to be the probe at fault,but there is a possibility that the pcb could also be the problem.Sorry I can’t be of any more use.
