DeDietrich FX4447E single oven with pyrolytic clean setting. 97 36 04072.
Oven works fine on every setting except when on ‘pyroclean’ when it will cut out. Everything dead including the clock. If it’s left to cool, comes back on.
So it must be the safety TOC acting. The cabinet cooling fan is running OK.
The last time the customer set it to pyroclean it cut out and the clock now cannot be set at all.
The clock controller is not that expensive but what on the pyro control could be causing this? Is there a separate stat limiting the pyroclean heat? Or does it rely on the oven stat?
Thanks, Ken, I’d really appreciate that. Trouble is, everything gets so hot you can barely touch it. Then, just as you’re getting somewhere, it all comes back on. 👿
Mail sent with it Steve but there’s some problems this morning with email and DNS stuff at the data centre in London so it may take a while to get there.
