DT1304 JE11 L462DD111
The 2 right hand plates dont heat up. You can select heat setting and the number flashes but just keeps flashing. Ive had a look inside and basicly each side has 2 large power boards and 2 touch pad display boards. The plates have continuity through them and there is no obvious signs of damage on the board although I suspect the main board to be at fault.
Anyone have any experience with these please.
Sounds like it is not detecting the pans or that the wrong pans are being used.. assuming that the correct pans are being used, I would say you have a problem with the largest of the 2 boards.
