Defrost cycle on F/F Freezer?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Defrost cycle on F/F Freezer?
  • #19137
    How does the defrost cycle work, or rather what are the sequence of events in the process?
    I would love to know as I am a little concerned over my upright freezer, the fan seems to have been running for ages. Green light still on though thank goodness 😉
    Its a Proline by the way 🙁
    #181872
    clivejameson
    Re: Defrost cycle on F/F Freezer?
    Hi Martin….essentially the defrost the defrost process is controlled by a timer (used to be mechanical but now usually electronic) which periodically switches off the compressor circuit and switches on a defrost heater to melt any ice build-up on the evaporator. The heater is controlled by a small stat or thermistor which switches off the heater when it’s above zero i.e. the ice has melted.
    After a set period, the timing device switches the heater cicuit off and the compressor back on to continue with the cooling process.
    If the compressor is continuously running it suggests there may be a problem as it itself is controlled by a stat (probably the pcb in your case). Most likely the compressor is a little worn and struggling to keep the cabinet at a low enough temperature….if the fan is continuously running on it’s own then you need to check that the compressor is actually running. If the compressor is red hot and not running then you’ll prolly need a new freezer i’m afraid 😥
    #181873
    Excellent stuff Clive thanks 🙂
    The fan has in fact shut off right now and all is still and seemingly normal. I’ve never known the fan to run for such a long time and I honestly don’t think the compressor was running at the same time – dunno?
    But now I have and idea as to its function I will keep an eye on it. By the way I’m pretty sure it must have a mechanical defrost timer on this beast (nothing electronic as I can detect?)
    Thanks again!
