Re: defy spares
I found this:
Defy wrote:ยป DEFY OWNERS OUTSIDE SOUTH AFRICA
It may be possible that the freight and import taxes far exceed the economic viability of importing parts. Therefore we suggest that you contact your local repair and spare specialist and try to obtain compatible parts, e.g., where this may be possible:
* Compressors and thermostats for refrigerators.
* Spiral and solid plates, switches for these plates.
* Thermostats, elements for stoves, ovens and hobs.
In case of front load autowashers, the original design was a European origin and items such as motors, fan belts, thermostats and timers may have compatibility with other products in your country.
However, should all else fail the parts can be supplied ex South Africa by sending an email to iholland@defy.co.za.
The following information is required:
* Model number
* Serial number
* Description of item
* Function of item
Unless anyone else knows ?
Maddocks are probably a god bet as well.
