Deietrich VN8888U1 dishwasher leak
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Deietrich VN8888U1 dishwasher leak
  • #38713
    trotter
    I had a call out to this one today, it appears to be leaking from the bottom of the door.
    I am guessing it is the seal, although it looks okay. I tried to order one but it is coming up as no longer available (Connect list an alternative) I wonder if anyone is aware of a mod?
    Maybe that is why the seal is unavailable?
    Any help gratefuly received 😕
    #259743
    Re: Deietrich VN8888U1 dishwasher leak
    31X9540 – 3 sided door seal.
    31X8631 – lower door seal.
    Usual leak is caused by split in lower spray arm – 31X9985.
    aqualectric
    Also overfilling from that lovely water matrix behind the left side panel……sticky level float microswitch, scaled or general crud in the tubes of the matrix, blocked lower transfer hose from sump to matrix……. 😉
    HTH,
    Steve.
    #259745
    aqualectric wrote:blocked lower transfer hose from sump to matrix……. 😉
    Mmm, nice – not 😀 .
    Dales-Electronic
    As Chris says – check the spray bars for splits first 8)
