Deloghi dfs903 Range Cooker problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Deloghi dfs903 Range Cooker problem
  • #81502
    Mike_G
    We have looked at a Deloghi range cooker; dfs903.
    Initially the programmer had burnt out, so we replaced the programmer and all seemed OK.
    However, after putting on the oven (under any setting, grill, fan oven etc) it cuts out after a maximum of 10 minutes working.
    Is this an issue others have seen? There is still power, however, no programmes can be selected, and we have to wait for the cooker to become ‘active’ again – this can take anywhere from 30minutes to 2 days?!
    Mike
    #416844
    SWERV
    Re: Deloghi dfs903 Range Cooker problem
    When you say it cuts out, does the clock go off as well?. If not, things that I have done on these are, countless selector switches, also toc’s and I would also check the terminal block.
    Sent from my iPhone using Tapatalk
    #416845
    Mike_G
    Thanks SWERV – my gut tells me TOC? Clock stays on! There are two TOCs, might just swap them both, as they are fairly inexpensive.
    Mike
    #416846
    SWERV
    Certainly worth checking the selector switch for burnt contacts as well.
