Delonghi coffee machine makes buzzing noise
Home Forums Public Support Forums Help And Support Other Appliances Delonghi coffee machine makes buzzing noise
  • #103132
    Kommunist
    I have a 10+ years old bean to cup coffee machine (Delonghi Primadonna Deluxe S), which I really like.
    Unfortunately, it started to make a loud buzzing noise when making coffee (the coffee is fine) and it takes twice as long to make a cuppa.
    Spoke to Delonghi, they’ve said that because the machine is so old, it is beyond of economic repair and advised that I’d be better off scrapping it and buying a new one.
    Surely it should be possible to repair the machine rather than sending it to a skip?
    I’ve searched on the web and it looks like the pump is on its last leg, plus there are a lot of other potential issues like relays and stuff. Some even say there is something wrong with the boiler…
    Any advise is much appreciated. Oh, and if there is an engineer around Northampton who can fix that machine, I would like to know their details 🙂
    #491883
    have you put a descaler through it recently ?
    if the pump is not pumping properly they make a noise
    Kommunist
    Not recently, no. I only descale it when it is asking for it, I think the last time I did it was about 2 months ago.
    #491885
    well its a long shot but its cheap and easy
    if you have a valve in the pump jammed through scale or a stuck pressure relief valve it would give your symptoms
    Kommunist
    Are you suggesting I shall run a descale cycle? Can do, after all, as you’ve said, it is cheap and easy.
    #491887
    Kommunist wrote:Are you suggesting I shall run a descale cycle? Can do, after all, as you’ve said, it is cheap and easy.
    yes
    its a long shot but cant hurt
    Kommunist
    electrofix wrote:
    yes
    Descaled the machine today twice.
    It made no difference at all.
    It sounds, however, that the buzzing noise is happening when the machine is taking water from the tank and putting it to boiler. When it is pumping the water out through the hot water spout there is no noise, just the usual whirring.
    #491889
    well there is only one pump
    weird that it make a noise sometimes not others
    does it seem to pump water ok ?
    Kommunist
    Yes, it pumps water OK, no issues with either water flow or coffee taste.
    #491891
    the buzzing noise is normally a pump problem where the pump armature is travelling too far too fast. its normally associated with air in the unit or low water level. it can be caused by faulty or blocked pump valves.
    but your saying it pumps ok so am a bit lost as to why its doing it
    Kommunist
    I’ve seen some videos on youtube where people are blaming it on 3-way solenoid. Not sure if it is correct or not, though.
    Apart from the noise the machine operates perfectly well and the coffee is as good as on day one.
    #491893
    all you can do is take the covers off and with care and safety in mind operate it and see if you can determine where the noise is coming from
    Kommunist
    Will do! Thank you!
    #491895
    Kommunist
    electrofix wrote: all you can do is take the covers off and with care and safety in mind operate it and see if you can determine where the noise is coming from
    An update – ran the cleaning a couple of times again during last months and the buzzing noise is gone. Thank you for your help!
