Re: Delonghi DFS090DO
There is a countersunk screw either side of the top rims (at the top front corner of each side panel)and a further 2 screws at the back corners of the hob. Remove side trims. Remove all burners; further screws under the burners – don’t miss them! Hob hinges up and the screws for the control panel are on top.
Shouldn’t need to remove the control panel though; the selector switch screws are accessible behind the knob (might need to push the insulation back a few mm): but to swap the switch the hob has to be lifted.
Word of warning – the hob has no prop and the edges are razor sharp!!
HTH,
Steve.
