Re: DeLonghi DFS901SS
Is the door sealing?? If it is there is not much that can be done as there is no adjustments on these doors
When shutting the door does it touch the seal at the top then open up a gap between door and seal?? If it is doing this then remove the door and check the rollers within the oven door hinge receiver. This roller should not be able to move up and down. They have a habit of wearing and not holding the door firmly closed. rplace these and door will close firmly.
Geoff
