delonghi dsc95e not getting hot enough
Home Forums Public Support Forums Help And Support Cooker And Oven Forum delonghi dsc95e not getting hot enough
  • #71736
    bigt2811
    Hi guys i need help with my cooker it a delonghi dsc95e 90cm range the fault is the oven not getting hot enough it reaches about 80 – 90 degrees and no hotter i have replaced the thermostat the thermal limiter and the thermal cutout and the problem is still there i have also checked the elements there are three top, bottom, and circle/fan all check out on continuity and as i see it they either work or dont i did notice the replacement thermostat was a bit shorter in the length of the probe wire so is a bit tight could this be the problem cheers any help would be great as the cooker cost me a lot and so far has cost me £60 in parts
    does anyone know where i can get a multi function switch for this cooker as it seems to be burnt at one of the terminals
    #382111
    Re: delonghi dsc95e not getting hot enough
    A quick email to Dave on spares@ukwhitegoods.co.uk will get you the correct parts.
