Can you please advise where I can buy a replacement oven fan for a Delonghi ESS601W cooker.
The symptom is that the fan takes a while before it comes on (and this time is getting longer), which can’t be doing the element much good !. I’m not sure whether the fan motor has brushes and therefore whether a simple replacement of brushes may do the trick. Even so, is changing the fan the better option ?.
Motor replacement is the best bet to be honest, there are no brushes in it. Sometimes lubrication can help but temporarily. Fan motor here if you need it 🙂
