Delonghi MW865 Microwave no micro function
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Delonghi MW865 Microwave no micro function
  • #29258
    Sparkcymru
    This ones driving me mad. Microwave function was blowing internal fuse as soon as Magnatron starts up with a loud noise. Replaced Magnatron and all worked well for 3 months, then the microwave function only worked after a long delay or not at all. Replaced PCB and no change, capacitor and transformer replaced as well and fitted another Magnatron just in case, and now loud noise again at start up and internal fuse blows again. All other functions work fine. Anyone got a schematic for this machine or ideas where else to look?
    Thanks. Steve.
    #222499
    Re: Delonghi MW865 Microwave no micro function
    dont know this one of hand but am assuming you only blow the fuse when micro starts ie you set time and push start button
    disconnect mag disconnect diod disconnect wire from transformer ht
    make sure these cant touch anything
    turn on try microwave if blows is transformer
    if not switch off reconnect capacitor try again if works again DISCHARGE!!! and reconnect diode and so on this is the way i find hv faults that will not show on meters
    hope this helps but be carefull without the mag in circuit you will be left with a full charge on the cap
    SWERV
    It could possibly be the short protector, if it has one fitted on this model. Resistance readings will not show up if using a dmm.
    Merv
    #222501
    expertcat
    test the capacitor with a megger this will show you charge state.
    Also test the diode assy with a multimeter.
    You should not test hv unless you know all the pitfalls as a wrong move will either kill or blow a part of your anatomy off.
    #222502
    Check the diode and door microswitch’s
    Bryan
    #222503
    Sparkcymru
    Ok well thanks for all that i’ll let you know how I get on.
    Steve
