Re: desperate help needed diplomat apm8552
Let’s seperate this out a bit…when you say the pump makes a horrible noise there may be a foreign object in it (strip it open and remove) or it may be that the pump is badly worn (strip it open and check for excess play by moving the impellor side to side…there should be little or no play)
Given either of the two faults above, this would stop the machine draining which in turn would prevent it from spinning (not tumbling)
If on the other hand the motor refuses to turn at any time then we’re looking at motor/module faults which is time to either get a meter out or an engineer in 😉
If you need professional help try the link below?
