desperate w/pool d/wsher ADG7540 top b/skt sprayarm grommets
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts desperate w/pool d/wsher ADG7540 top b/skt sprayarm grommets
  • #20852
    TELL
    im after the part no’s for the grommets, gasket’s ? for the back of the top spray arm. the tube is still there, but the seals are not, they are missing. dont know what i’m looking for with only part no.s in front of me. the water is not being direct into the top basket spray arm, it’s getting pushed out of the side, so obviously not washing on the top basket.
    can any one give me the part no.s i need to order.
    thanks TELL..
    #188565
    Dave_Conway
    Re: desperate w/pool d/wsher ADG7540 top b/skt sprayarm grom
    Upper spray arm assy complete with pretty much everything inc the docking unit at the back is part number 481236068349 🙂
    #188566
    TELL
    dave,
    have put in the part no, given, everything the picture shows, i still have on the top basket.. is there no seals,or grommets at the back, (coupling) to stop the water leaking out sideways between the rear connecting column and rear of the spray arm??. it looks as if somthing was there, but now its missing.
    TELL..
    #188567
    It’s the whole bag of mashings, Tell – the docking bit, the tube across the basket and the rotor assembly. I’d assume it’s everything. Quote the customer £45 and stick your time on top 😀 .
    TELL
    ok. thanks dave.
    TELL..
