Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Detergent Door Fails to Open on Bosch Dishwasher
- This topic has 5 replies, 3 voices, and was last updated 20 years, 5 months ago by
Shaunf.
October 30, 2005 at 9:48 am #12927
Shaunf
ParticipantThe latch on the detergent compartment of our Bosch dishwasher (SGS6302GB/07) seems to stick and the plastic door fails to open to dispense the tablet during the cycle. If I press the lever next to the plastic door, the plastic door pops up and to the right ever so slightly, but it then seems to snag on something and I then have to push it open with my hand. Has anyone else had this problem? and if so, what was the solution?
Thanks.October 30, 2005 at 10:34 am #152275Martin
ParticipantRe: Detergent Door Fails to Open on Bosch Dishwasher
The latching has worn and needs replacing, individual parts are available but I recommend replacing the complete Dispenser Unit. Often much the better option at just £31.61 but tricky to replace as it’s easy to damage the stainless steel inner door panel in so doing.
The part number is 263088 and it can be obtained direct from Bosch via this link:-
http://www.bshappliancecare.co.ukA local engineer can do the job for you via this link:- Repairs@
November 1, 2005 at 12:20 pm #152276Shaunf
Thanks Martin, I think this looks too risky for me to do myself, I’ll call someone.
November 2, 2005 at 5:24 pm #152277Shaunf
Has anyone ever looked to see what actually gets worn out on these latches? When I removed the door on the dispenser unit the mechanism looked pretty simple (not much to go wrong), but when I replaced it I couldn’t see what was actually snagging. It would be a shame to replace the whole dispenser unit if all it needed (for example) was a new spring.
Thanks.November 2, 2005 at 5:39 pm #152278Martin
Shaun,
My recommendation still stands, but if you insist on replacing the individual parts, then thats not a problem either 🙂
Just click on this link and make your choice: – http://kundendienst.consultens.de/gb/BS … e_Care.htm
November 2, 2005 at 9:16 pm #152279Penguin45
I’ve already told you this once………
http://www.ukwhitegoods.co.uk/modules.p … pic&t=9186Will posters please try and keep related problems to a single thread.
Penguin45,
Moderator. -
