Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › DHB7VTDB bush tumble dryer
- This topic has 9 replies, 3 voices, and was last updated 6 months, 1 week ago by
HotDog.
September 25, 2025 at 6:04 pm #103579
HotDog
ParticipantNeed a fan belt for this dryer it’s a round rubber belt that don’t seem to last long some time ago I fitted a fibre stretch between on one of these but I had no part number long shot but has anyone found a good alternative if not we’re can I get the original one
September 25, 2025 at 8:32 pm #493795don
ModeratorThe part number for the original belt is 101070080002 ASWO perhaps?
Don
September 25, 2025 at 10:04 pm #493796electrofix
Moderatordon wrote:The part number for the original belt is 101070080002 ASWO perhaps?
Don
no one has stock
is there a size on the belt
September 26, 2025 at 10:54 am #493797HotDog
ParticipantNo size on the belt Dave it’s a clear plastic belt there is a belt on eBay that claim it fits you cut to size without the need to remove drum support I have ordered one will see if it works not cheap £34
September 26, 2025 at 11:40 am #493798don
ModeratorNo size listed on part description either.
Don
September 26, 2025 at 1:51 pm #493799electrofix
Moderatorseems to be cheaper options
one supplier said this belt also fits models
DHB7VTDB
DHB7VTDW
TDV7NBB
TDV7NBWtaking that and do google search for belt for the other models
[USER=”125″]don[/USER]where did you get part no from as comes up on minerva as a bearing
https://minervaparts.co.uk/gb/search?controller=search&s=101070080002Dave
September 27, 2025 at 9:32 am #493800don
ModeratorOn Minerva.
101080080003 for belt 🙂 that XL spreadsheet is 2 lines out, I looked at pos 65 and then went down list to that whereas it’s really line 67. Rookie error!!!
Don
September 29, 2025 at 9:14 pm #493801HotDog
ParticipantWell the belt from eBay when cut to size and joined with a small brass connecter works but I have now found a supplier of the same thing in china £5 I have ordered to compare
September 30, 2025 at 11:49 am #493802don
ModeratorCan you let us know the size please for future reference as someone else further down the line may also be looking.
Don
September 30, 2025 at 2:16 pm #493803HotDog
ParticipantWill do you just have to trim the tube to suit the dryer then join the 2 ends with a very small brass coupling so size to suit
