Re: DIAGNOSTIC / RESET MODE FOR ZANUSSI FJS 1225 W AND WJD 1
Switch machine off. Press and hold START and SKIP/RESET buttons while switching machine on. After about 4 seconds the machine will bleep, release the two buttons. All of the lights will flash around in sequence. Press the fabric button 9 times and you should have the last stored error code. To exit the fault system press the Temperature button a couple of times then switch machine off then on then off again. When you switch back on it will probably display EE0, switch off again then back on and you will be back to normal use. 🙂
