have a hotpoint with a 43er101c1 fitted a 48er101c1 which i believed was the update. all connections the same. didn’t work cooling fan on when off not working half grill etc. on connect it says
The original regulator (Diamond h 43ER101C1) Was replaced by ego regulators and a tech bulletin C151 was produced for th is. The ego regulators are no longer being used and have bee n replaced by diamond h 48ER101C1 which is compaitable with the original regulator. Tech bulletin C151 no longer applie s and is not required.
onthe sticky on here it says put in a link for 43 and 48. is that what it needs or could it be a faulty switch
thanks
