Diamond H wiring conversion?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Diamond H wiring conversion?
  • #65635
    TELL
    Ive been to a Belling range cooker model 930 BL, Stoves range 058560037 S/no 050100010, needed a main oven stat, and 2 single energy reg’s diamond H type 31ER14MHT with pilot, these were the orignal on. Sourced the part No,s to 082617129 IF THESE ARE CORRECT?, which are also the new type Diamond H type 41E102C1P. I fitted them using the energy reg conversion charts on UK Whitegoods but these particular reg’s are not listed for the conversion, but had the same configuration on the chart, But when fitted they did not regulate at a low setting, and also I had no pilot lamp indicating that they were on. the wiring contacts are below for the reg’s
    31ER14MHT (Old) (New) 41E102C1P -Has connections below
    P2 Neutral – 4A Neutral
    2 Load – 2 Load
    P1 Live – P1 Live
    S pilot – 4 Pilot
    P2 ?? thinking this for a dual. but not a daul reg,
    when the wiring swapped over on to new reg, as I said as above
    Are these the correct regulators for the Belling cooker, or have I missed something in the changing of the wiring,or is the wiring different for these reg’s, if so can somebody inform ne,thanks
    TELL..
    PS tried the link P1 to 4 No good
    #361356
    spanner51
    Re: Diamond H wiring conversion?
    Have a look at the sticky ‘Diamond H Wiring Reference’. It should tell you what you want
    #361357
    TELL
    Hi Spanner51, been on that site for cross reference of the connections, but did not work, listed terminals as above, and the regulator reference codes are not on that list, as above.
    TELL..
    #361358
    spanner51
    I’ve not come accross your prob before. You could have a llok at this
    http://www.diamond-h-controls.com/image … ators1.pdf
    http://www.diamond-h-controls.com/40er_ … tors.html#
    HTH
    #361359
    TELL
    looks promising , will check over after the w/end
    thanks spanner.
    ps if there is any other info, greatley recieved.
    TELL..
