Diamond H Wiring Reference
  • #19875
    MickGeorge
    Hi Folks
    Is the above reference for Diamond H Controls for the dual control double live (think the ref used to be ER27) or the dual control live/neutral (ref ER23). Presume the later as don’t come across the switched double live much these days.
    Just having trouble with one of these from Connect ELE4110 where the accompanying diagram is telling me to bridge a wire across what appears to be L and N !!!!
    Hope the stickey might help
    #184846
    MickGeorge
    Re: Diamond H Wiring Reference
    Just been back to this one and it looks like there are 2 types of simmerstat that are simmiliar but switching live and neutral .the one that is listed in the “stickey” which appears to be a Dimond H 33ER3HT and the one that I have just come accross a Dimond H 43ER105B1 supplied under Connect No ELE4110
    Although the wiring convertion supplied by connect is correct the additional diagram for the link wire is not.
    Correct connections are as follows
    Pilot = S2
    Line = P1
    Load A = 2
    Neutral = 4
    Load B = P2
    Link wire for Pilot wire fits between P1-S1 NOT P1-4 as additional wiring diagram suggests. :rolls:
    Not sure if this has been a previous post or not and if you want to include this in your “stickey” Dave – up to you.
    Hope this of help to others out there… 🙂
