Even though I have power to the left side of the hob the power indicators
only flash as if their was no pot on the hob, while at the same time there is a clicking sound from below the glass. Any thoughs or idea’s would be welcome. Model No. DTI199XE1 HCH system, bought this 4 years ago but only fitted it last week.
Hi K,
Ain’t that a bitch, guess I will work away on the right side until I have time to remove the PCB, if I find a fault Iwill post it here. Thanks for the reply.
regards B
Hi Bryan
doubled checked the wiring and all is ok. Removed hob and opened up, internal wiring ok, also removed PCB did a visual with a magnifying glass no dry joints or obvious damage.
