DIF04 dishwasher wash pump.
  • #58801
    gadgetdad
    Hi, got the usual (it seems) spray arms not turning problem.
    Takes in water, heats up, pumps out but does not wash. Stripped off wash pump – looks like huge waste pump and seperated the heating element from the end – now heres the question — the impeller just pulls off the shaft to show a sort of drive cam with two rubberish dogs that seem to just sit in the base of the hole – is this correct – surely the impellor should not be able to just pull off.
    The drive arrangement is strange – if this is correct then the only way Incan see it working is on centrifugal force – as the shaft spins the rubber dogs are forced out and grip the sides of the impeller to make it turn !!
    Has anyone replaced/seen the inside of this type of wash pump – or shall I just replace the whole unit.
    Cheers
    gadgetdad
    #335737
    geoff1
    Re: DIF04 dishwasher wash pump.
    On the indesit dif04 dish washer it would be the pump with impeller assy part number C00256525.
    Reminds me of the one fitted to the whirlpool/hygena dishwashers that used to fail
    Geoff
    #335738
    There has been a high incidence of pump failures on this model and its Hotpoint clone. 😥
    #335739
    Simon46
    Just as a matter of interest the rotor/impellor assy has a tab which locates on pump body. How do you know when you twist fit it its not moved out of position? blob of debor before fitting?
    S.
    #335740
    washtronics
    fitted loads of wash motors and heaters on ind/hot newer type dishwashers, they only last for 2-3 years max, carry both on my van as use them so often. Suppose this is progress for you!
