Dimplomat / Limona HJA 8552 won’t start
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Dimplomat / Limona HJA 8552 won’t start
Viewing 1 post (of 1 total)
  • #84244
    MikeT999
    Hi – we have a washing machine purchased from howdens around 7 years ago – model number HJA 8552 (which i gather is a either a Dimplomat or Limona brand).
    We turn the machine on and select a normal 40 degree wash, at this point the ‘Stop’ LED is blinking every second. If I press the start button, I can then hear water running through the detergent drawer. Water runs for around 5 seconds, then all activity stops. The Start LED remains lit, as does the door lock LED, and nothing is flashing.
    It has, on a couple of occasions, filled the bottom of the drum with a couple of inches of water, and selecting the ‘drain’ program has drained the water away.
    The Spin function works fine.
    I have removed the back cover and located a sensor with 2 wires in the rear of the drum – I assume this may be a temperature sensor. I have removed it and cleaned the muck off it, but it made no difference.
    Does anyone have any ideas what to try next?
    Many thanks in advance.
    Mike.
