Diplomat 60/40 fridge freezer not cooling
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Diplomat 60/40 fridge freezer not cooling
  • #69589
    b21playa
    Hi all
    I have a diplomat built in fridge freezer purchased from MFI about 4years agoh
    Realised yesterday the stuff in the fridge had gone off and realised it was as the fridge was warm. At this point freezer looked ok.
    I could not hear the compressor but after turning thermostat up, and messing about with it, it seems to have kicked in. Since it has stopped again
    Can anyone provide any help?
    Thanks in advance
    #375307
    SAMURI
    Re: Diplomat 60/40 fridge freezer not cooling
    I will need the model number to advise
    Bob
    #375308
    b21playa
    #hi
    Just taken out fridge, but can not see model number
    #375309
    SAMURI
    The model number should be inside the fridge compartment.
    Normaly on a label to the left or right you should see it if you take out the salad box’s
    Bob
    #375310
    b21playa
    SAMURI wrote:The model number should be inside the fridge compartment.
    Bob
    Ah ha……found it
    Apm6012
    20072908060 – 038103005 – 03
    #375311
    SAMURI
    The most likely fault will be the electronic module.
    It is Unlikly to be any other fault on this model.
    If you fit a new module make sure you have It set to maximum before turning the power back on otherwise you may think it is not working.
    If you turn the module on after the power it has a delay of about 10 minutes before it will start
    Bob
    #375312
    b21playa
    SAMURI wrote:The most likely fault will be the electronic module.
    Bob
    Where can I get the module from and how much are they?
    #375313
    SAMURI
    From the white goods shop on this site not sure of the price.
    If not then post again and I will give you another supplier.
    Bob
    #375314
    b21playa
    SAMURI wrote:From the white goods shop on this site not sure of the price.
    Bob
    At £85 an expensive part
    #375315
    b21playa
    What goes wrong with the electronics module?
    #375316
    b21playa
    could it be the thermistor on the pcb?
    #375317
    b21playa
    Managed to get a digital thermometer to check the temp
    The freezer was -16.5deg and the fridge was +11deg.
    #375318
    b21playa
    Model: apm6012
    Freezer is cold, but fridge sometime gets down to 4deg, other times 12-16deg
    Where is the hole/fan when the cold from freezer is circulated to fridge
