Diplomat 710 model Number 058587036 un-timely demise..help!
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Diplomat 710 model Number 058587036 un-timely demise..help!
  • #50040
    deadcooker
    Hello – is anyone out there…..
    My cooker as above has died..
    a couple of friends have had a look and we have identified that the probable cause of it’s untimely demise is possible resistance burnout on the little black plastic mounting on the back of the oven.
    Please can some one advise if this is replacable and if so where do I find one… none of the cabling under the outside metal casing are visibly damaged. only where the main flex comes from the socket into the oven…
    Where next chaps – :rolls: …
    CH x
    #303122
    Re: Diplomat 710 model Number 058587036 un-timely demise..he
    Mains terminal block where the power comes in?
    Find the “ADP—-” reference and spares@ukwhitegoods.co.uk should be able to source it for you.
    deadcooker
    Thanks mr Penguin … Yep I think it’s the terminal block… I’ve found one for £7.44 so I think that a pretty good place to start..
    Many thanks
    for the reply..
    Catherine
