Diplomat 8234 Dishwasher
  • #27250
    squadman
    Had a E3 Error code at end of program 6 which is a 70c cycle, customer reporting no heat.
    Found that reset thermostat had activated ( stat with red button front left hand side ) Reset and checked element for continuity and insulation OK.
    Put on cycle machine now heating ok, however had a call from customer today saying that the machine was now heating but error code of E3 was showing at cycle completion . Have had another look but can find nothing other than the manual indicating heating circuit fault ?
    What have I missed here ?
    #213222
    Re: Diplomat 8234 Dishwasher
    It’ll be underfilling as per the E2 fault.
    squadman
    Penguin,
    Is that the metering tank in the side you refer to ?
    #213224
    Yup, transfer tube and tank clag up – machine under fills, safety trips.
    squadman
    Thanks Penguin
