Re: Diplomat 8242
Open door
Switch on with door on/off button
Within 3 secs (before display comes on) press programme button 4 times
Lights 1 & 5 should now be flashing (if not repeat until you have this situation)
Press programme button once more and you should be left with only the 5th light flashing.
Switch off (don’t close door)
Leave for a few seconds then switch back on.
Select programme and close door
Machine should now work (stick it on a rinse – if it gets past the main fill you should be OK)
