Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Diplomat 8242 – No water intake
- This topic has 11 replies, 4 voices, and was last updated 17 years, 4 months ago by
jmcfem.
December 6, 2008 at 5:35 pm #41645
jmcfem
ParticipantI have a problem with dishwasher which is around 5 years old. It sounds as if water is being taken into dishwasher but this does not actually happen.
Error lights are 1st 3 flashing and 5th constant.Any ideas??
December 6, 2008 at 5:50 pm #270847Penguin45
ParticipantRe: Diplomat 8242 – No water intake
Code is no fill detected in the time allowed. Possible faults are water turned off, fill hose kinked/trapped or valve failure.
If the machine sounds like it’s filling, you should see water across the base inside.
Power off if you decide to investigate the water valve.
December 7, 2008 at 11:34 am #270848jmcfem
Thanks. There is water in base on unit.
Code has changed to 4th and 5th lights flashing.
Is this still to do with valve?
December 7, 2008 at 6:09 pm #270849WILLthesparky
i have the same problem , 4&5 are flashing and i cannot do anything
please help!!
December 7, 2008 at 6:45 pm #270850smartin
well put it this way if you have put rock salt in it then the chances are that is what has caused the base to flood, caused by over foaming, you could have asked that in here rather than pm me as lots of engineers will then view your post and offer an opinion on said problem.
December 7, 2008 at 6:53 pm #270851WILLthesparky
NO rock salt here that was just a random question… unrealated!
December 7, 2008 at 6:57 pm #270852smartin
remove plug then check base to see if its flooded
December 7, 2008 at 7:00 pm #270853WILLthesparky
yeh ive removed the silver panel below the door and there is a small amount of water inside
December 7, 2008 at 7:08 pm #270854WILLthesparky
if i clean it up should solve the prob?
December 7, 2008 at 7:30 pm #270855WILLthesparky
thanks !! i cleared the water and it has returned to “normal”
do you know of any special cycle etc i can put it through to test,check etc
or just do i see how i go??
December 7, 2008 at 7:50 pm #270856Penguin45
Find the leak! Commonest one is from the “O” rings on the right-hand side where the fill matrix joins the softener unit. Remove r/h side panel to observe.
December 7, 2008 at 7:53 pm #270857WILLthesparky
iyep ive fixed the leak definately stoppedn looks good is their some sort of a test cycle to put it on at all ?
