diplomat 8242 smeg type dishwasher
Home Forums General Trade Forum diplomat 8242 smeg type dishwasher
  • #67606
    QUICK FIX
    runs for a couple of mins then the first three lights flash 4th light not lit and the 5th light is permantly lit any ideas of fault and part numbers thanks
    #367944
    Criscold
    Re: diplomat 8242 smeg type dishwasher
    Looks like Flowmeter Fault
    #367945
    A1engineer
    probably just needs reset pm me your email ill send you some info
    #367946
    QUICK FIX
    have sent u my email address thanks
    #367947
    A1engineer
    cant find your email so ill stick answer here.
    With the door open, turn on the appliance and within three seconds push 4 times on the program selection
    button – The test program has been selected if the SOAK and STRONG LED’s (1&5) are flashing
    This LED combination represents the test program for the appliances that have a flow meter.
    If the above indication is not shown on the appliance, switch the appliance off and try the sequence again
    until the above LED’s are shown on display.
    Now push on the program button once more to select the version ‘without flow meter’, check that the SOAK
    LED goes out, and the display is indicating on-off-off-off-off.
    Do not close the appliance door, to complete settings switch the appliance off.
    Now switch the appliance ‘on’ and test on a SOAK program.
    #367948
    QUICK FIX
    thanks
    #367949
    QUICK FIX
    thanks again worked a treat
