Re: Diplomat 8242 strange problem
Erm, I’m not a D/w engineer, but i’d hazard a guess that you’re actually operating a LEVEL switch!
machine fills, switch trips….cycle starts 😀
I’d expect to find a flood -switch external to the main chamber,in order to detect water leakage into the casing”sump”
You do, of course, need to rectify the leak. the chemicals (salt, detergent, rinse-aid) do nasty things to the motor-windings, cables, connectors and solenoids.
I’d rinse -off the wetted components, give it 48 hours in a warm place to dry -out, then spray with WD40 before re-installing.
